Docker CE und CIFS volume von einem NAS
ich kann kein arm64 testen aber das mysql:latest funktioniert bei mir sofort
ein paar anpassungen musste ich an meine Umgebung machen
folgender Eintrag in der fstab
10.23.1.1:/vm-data/nfs-share /mnt/nfs-share nfs4 nofail,_netdev 0 0
anschließend mount -a abschicken
services:
  mysqldb:
    image: mysql:latest
    container_name: mysqldb
    restart: unless-stopped
    volumes:
       - /mnt/nfs-share/:/var/lib/mysql
    environment:
      MYSQL_ROOT_PASSWORD: extrageheim
      MYSQL_DATABASE: testdb
      MYSQL_USER: mysquser
      MYSQL_PASSWORD: mysqpasswd
    healthcheck:
            test: ["CMD-SHELL", "mysqladmin ping -h localhost -user==$$MYSQL_USER --password=$$MYSQL_PASSWORD"]
    networks:
      docker_subnet:
        ipv4_address: 172.18.0.102
networks:
  docker_subnet:
    external: true
Dateien werden angelegt im share als user/gruppe 999:999
ausgabe der log vom container
2024-10-16 10:19:35+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 9.0.1-1.el9 started.
55
2024-10-16 10:19:36+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
56
2024-10-16 10:19:36+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 9.0.1-1.el9 started.
57
'/var/lib/mysql/mysql.sock' -> '/var/run/mysqld/mysqld.sock'
58
2024-10-16T10:19:36.280603Z 0 [System] [MY-015015] [Server] MySQL Server - start.
59
2024-10-16T10:19:36.477729Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 9.0.1) starting as process 1
60
2024-10-16T10:19:36.485963Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
61
2024-10-16T10:19:36.993176Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
62
2024-10-16T10:19:37.355471Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
63
2024-10-16T10:19:37.355496Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
64
2024-10-16T10:19:37.360193Z 0 [Warning] [MY-011810] [Server] Insecure configuration for --pid-file: Location '/var/run/mysqld' in the path is accessible to all OS users. Consider choosing a different directory.
65
2024-10-16T10:19:37.437157Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '9.0.1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 MySQL Community Server - GPL.
66
2024-10-16T10:19:37.437165Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '::' port: 33060, socket: /var/run/mysqld/mysqlx.sock
für mich sieht das so aus das alles normal leuft, der startet nicht ständig neu
erstmal vielen Dank für die mühe. Ich habe inzwischen eine andere Lösung. Ich kann auf meinem NAS eine Datebank laufen lassen und benutze einfach diese.
Nochmal vielen Dank
