Pimox - Proxmox for RPi + ARM
Here is the unofficial Pimox repository for Proxmox on Raspberry Pi and other ARM64 platforms: GitHub - pimox/pimox7: Proxmox V7 for Raspberry Pi
Install from „scratch“, RPiOS64bit Interactive Automatic Installer
Flash and startup the latest image from https://downloads.raspberrypi.org/raspios_arm64/ .
sudo -s
curl https://raw.githubusercontent.com/pimox/pimox7/master/RPiOS64-IA-Install.sh > RPiOS64-IA-Install.sh
chmod +x RPiOS64-IA-Install.sh
./RPiOS64-IA-Install.sh
Follow the prompts
Manual installation
Prechecks
  1. Pre-installed Debian Bullseye based 64-bit OS (not 32bit)
  2. In /etc/network/interfaces, give the Pi a static IP address. You cannot use dhcp.
  3. In /etc/network/interfaces, remove any IPv6 addresses.
  4. In /etc/hostname, make sure the Pi has a name.
  5. In /etc/hosts, make sure this hostname corresponds to the static IP you previous set.
  6. Make sure the kernel-headers are installed.
Installation
  1. echo „deb https://raw.githubusercontent.com/pimox/pimox7/master/ dev/“ > /etc/apt/sources.list.d/pimox.list
  2. curl https://raw.githubusercontent.com/pimox/pimox7/master/KEY.gpg | apt-key add -
  3. apt update
  4. apt install proxmox-ve (use a local attatched console! Network connections will be lost/reset during installation progress)
