version: „3“
services:
adguardhome:
image: adguard/adguardhome
container_name: adguardhome
ports:
- 53:53/tcp
- 53:53/udp
- 784:784/udp
- 853:853/tcp
- 3000:3000/tcp
- 80:80/tcp
- 443:443/tcp
volumes:
- ./workdir:/opt/adguardhome/work
- ./confdir:/opt/adguardhome/conf
restart: unless-stopped
Mit dem Fehler: Failed to deploy a stack: compose up operation failed:
Error response from daemon: failed to set up container networking: driver failed programming external connectivity on endpoint adguardhome (3dc29c2df81af674cca734da44842e9fe0c4d35d744baad5329e802e1b4ce380): failed to bind host port for 0.0.0.0:53:172.19.0.2:53/tcp: address already in use
